[gdal-dev] get gdalinfo output with a python script
Even Rouault even.rouault at mines-paris.org
Tue Jun 8 15:41:26 EDT 2010
http://trac.osgeo.org/gdal/browser/trunk/gdal/swig/python/samples/gdalinfo.py
Would need just a few minor changes to work against GDAL 1.7 python bindings
Le Tuesday 08 June 2010 19:51:50 Eloi Ribeiro, vous avez écrit :
> Hi,
> I don't manage to get all the info from a GRIB file with a python script as
> it's possible with gdalinfo output.
> gdalinfo output example from a GRIB band:
> *Band 1 Block=720x1 Type=Float64, ColorInterp=Undefined*
> *  Description = 2[m] HTGL="Specified height level above ground"*
> *  Metadata:*
> *    GRIB_UNIT=[K]*
> *    GRIB_COMMENT=Minimum Temperature [K]*
> *    GRIB_ELEMENT=TMIN*
> *    GRIB_SHORT_NAME=2-HTGL*
> *    GRIB_REF_TIME=   283996800 sec UTC*
> *    GRIB_VALID_TIME=   284000400 sec UTC*
> *    GRIB_FORECAST_SECONDS=0 sec*
> Till now I manage to get all Metadata tags but not all the info from the
> tow first lines.
> I am using the following code:
> *from osgeo import gdal*
> *dataset = gdal.Open(filename, gdal.GA_ReadOnly)*
> *if dataset is None:*
> *    print 'Nao foi possivel abrir a imagem!'*
> *for nBandas in range(1, dataset.RasterCount + 1):*
> *    banda = dataset.GetRasterBand(nBandas)*
> *    BlockSize = banda.GetBlockSize()*
> *    DataType  = gdal.GetDataTypeName(banda.DataType)*
> *    Metadata = banda.GetMetadata()*
> *    for chave, valor in Metadata.iteritems():*
> *        print chave, '=', valor.strip()*
> I would appreciate some help.
> Thanks in advance.
