[gdal-dev] Does anyone have built/compiled 64 bit versions of either FWTools or gdal
Tamas Szekeres szekerest at gmail.com
Wed Jun 9 03:03:08 EDT 2010
2010/6/9 GeoSpatial - Kevin <gs.kevin1 at gmail.com>
> Has someone already documented the performance difference between x32 and
> x64 versions of the FWTools / gdal? Improvement by how much? Many thanks.
Kevin,
I don't expect too much difference in performance, and I'm not aware of any
compare results. However one can do a compare by using the packages from
http://vbkto.dyndns.org/sdk/ which have been compiled by using the same
settings for x86 and x64. Any feedback on the experiences are highly
appreciated.
Best regards,
Tamas
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20100609/1310d6d6/attachment.html
