[gdal-dev] ESRI file geodatabase support
Eduardo Kanegae eduardo.kanegae at gmail.com
Wed Jun 9 16:32:13 EDT 2010
thanks for the help Frank,
Or in less words: this support is still in development and we probably have
to think in other solution to read fgdb´s using MapServer or other based on
OGR or FDO interfaces.
Eduardo
2010/6/9 Frank Warmerdam <warmerdam at pobox.com>
Eduardo Kanegae wrote:
>> Hi,
>> I´ve this topic at Google
>> http://osgeo-org.1803224.n2.nabble.com/When-or-if-OGR-can-support-ESRI-file-geodatabase-td2592778.html
>> Is there any plan for OGR on supporting this ESRI format or this will
>> depend on 'when' ESRI be able to open this format specification.
> Eduardo,
> Ragi Burhum has offered an ArcObjects based solution/driver for reading
> file
> geodatabases for those with an ArcObject license.  I'm not sure what the
> exact status of that driver is since I'm not in a position to help with it.
> For a less encumbered solution for file geodatabase we are effectively
> waiting to see what ESRI provides in the manner of an SDK for reading them.
> Once we have that, it is also not clear who, if anyone, would turn it into
> an OGR driver.
> Best regards,
> I set the clouds in motion - turn up   | Frank Warmerdam,
> light and sound - activate the windows | http://pobox.com/~warmerdam<http://pobox.com/%7Ewarmerdam>
> and watch the world go round - Rush    | Geospatial Programmer for Rent
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20100609/616d0f8a/attachment-0001.html
