[gdal-dev] ESRI file geodatabase support
Ragi Burhum ragi at burhum.com
Wed Jun 9 18:30:55 EDT 2010
Eduardo:
Not sure what you mean, but the ArcObjects OGR driver is, well, an OGR
driver. So it exposes things through an OGR interface. However the
ArcObjects side of things requires an ESRI license to run.
I have been using this driver in a production environment to load data from
FileGDB to PostGIS for the past 6 months without encountering any major
issues so far, so I have not really changed the code except for a few lines
in February to handle a small bug.
Feel free to get a Windows binary I built against 1.6
http://bit.ly/cNdrSr
If you want to know how to use it, I sent an e-mail to the mailing list
earlier
http://www.mail-archive.com/gdal-dev@lists.osgeo.org/msg05562.html
As far as the ESRI official SDK, AFAIK, it won't be worked on until 10 is
released (for my purposes, I couldn't wait for that, so that's why I wrote
the ArcObjects OGR driver).
Frank:
I'd be willing to create that OGR driver once the SDK is out, I just need to
have that SDK in hand :)
- Ragi
> From: Eduardo Kanegae <eduardo.kanegae at gmail.com>
> Subject: Re: [gdal-dev] ESRI file geodatabase support
> To: gdal-dev at lists.osgeo.org
> thanks for the help Frank,
> Or in less words: this support is still in development and we probably have
> to think in other solution to read fgdb´s using MapServer or other based on
> OGR or FDO interfaces.
> Eduardo
> 2010/6/9 Frank Warmerdam <warmerdam at pobox.com>
> Eduardo Kanegae wrote:
> >> Hi,
> >> I´ve this topic at Google
> http://osgeo-org.1803224.n2.nabble.com/When-or-if-OGR-can-support-ESRI-file-geodatabase-td2592778.html
> >> Is there any plan for OGR on supporting this ESRI format or this will
> >> depend on 'when' ESRI be able to open this format specification.
> > Eduardo,
> > Ragi Burhum has offered an ArcObjects based solution/driver for reading
> > file
> > geodatabases for those with an ArcObject license.  I'm not sure what the
> > exact status of that driver is since I'm not in a position to help with
> it.
> > For a less encumbered solution for file geodatabase we are effectively
> > waiting to see what ESRI provides in the manner of an SDK for reading
> them.
> > Once we have that, it is also not clear who, if anyone, would turn it
> into
> > an OGR driver.
> > Best regards,
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20100609/fcaf82cc/attachment.html
