[gdal-dev] ESRI file geodatabase support
Ragi Burhum ragi at burhum.com
Thu Jun 10 05:58:44 EDT 2010
> From: Eduardo Kanegae <eduardo.kanegae at gmail.com>
> Subject: Re: [gdal-dev] ESRI file geodatabase support
> To: gdal-dev at lists.osgeo.org
> Hi Ragi,
> You mean, unless I use this pre-built version you gave me (
> http://bit.ly/cNdrSr ) I´ll have to download GDAL sources + AO patches
> and then build at Win box my own GDAL/MapServer bins to read this
yes. And also, another requirement is to have an ESRI license (ArcView is enough) setup'ed.
