[gdal-dev] gdalwarp and GTiff creation option NBITS
Fri Jun 11 12:32:29 EDT 2010
Fischer, Andreas wrote:
> Dear list,
> I try to convert a raster images (GTiff) with gdalwarp. The images only
> have two colors (black/white) and the color table just have two entries.
> Therefore the file size for each image is exactly as big as needed
> (1bit/pixel). The result of gdalwarps transformation are images with
> 8bits / pixel and 256 entries in the color table. The file size for each
> image  is increased but in this case this is without benefit, because
> the results are still black and white.
> So I tried the creation option “-co NBITS=1”. Color Table und file size
> are now exactly as I expected,  but I can’t display the result properly
> with any program. For example IrfanView does fine, but unfortunately
> MapInfo Professional doesn’t. MapInfo Professional just shows irregular
> stripes. After opening the result file in IrfanView and saving it as a
> copy, the copy is displayed in MapInfo fine as well. I do not understand
> this behavior, because gdalinfo doesn’t show any differences.
Andreas,
It would be helpful if you could provide a tiffinfo report for each of
the three files.  It should reveal more of the low level tiff format
details which will be needed.
Best regards,
