[gdal-dev] ESRI file geodatabase support
Peter J Halls
P.Halls at york.ac.uk
Mon Jun 14 02:19:22 EDT 2010
Matt,
although we were told at the time that the EMEA 2008 Proceedings would be
put online, I've yet to see them or hear of the result - I was a speaker and
submitted my materials on time and as requested and that seems to have been the
end of the story.
Peter
Matt Wilkie wrote:
> The earliest reference I found to a "promise" of an open specification
> for file-gdb was ESRI UC 2006, with discussion where of a forthcoming
> public specification mentioned as far back as ArcGIS 8.3.
> In many discussions people seem to use the terms open API and open file
> format specifications interchangeably. ESRI itself seems to be pretty
> clearly sticking to API-only line though, from the 2007 UC:
> "While ESRI would ideally like to open the file geodatabase format in a
> manner similar to what we did for shapefiles when we released ArcView 2,
> geodatabases are complex and can be easily corrupted outside the ArcGIS
> environment. Instead, we plan to engineer a high performing and well
> documented API that developers can freely embed in custom applications
> and that will read and write file geodatabase datasets. This will be
> released after ArcGIS 9.3." -- http://bit.ly/esri-uc-qa-2007
> If you've a reference for talk of the file fromat spec though I'd love
> to see it. Searching for (EMEA) User Conference 2008 shows a few
> announcements for the event but no proceedings or blog reports; I'm
> likely not using the right keywords.
> I also echo the request for people attending *any* ESRI conferences to
> ask about both a public file format specifcation and programming API to
> the file geodatabase.
> best regards,
> matt wilkie
> Geomatics Analyst
> Information Management and Technology
> Yukon Department of Environment
> 10 Burns Road * Whitehorse, Yukon * Y1A 4Y9
> 867-667-8133 Tel * 867-393-7003 Fax
> http://environmentyukon.gov.yk.ca/geomatics/
Peter J Halls, GIS Advisor, University of York
Telephone: 01904 433806 Fax: 01904 433740
Snail mail: Computing Service, University of York, Heslington, York YO10 5DD
This message has the status of a private and personal communication
