[gdal-dev] GXF -- Grid eXchange File to AAIGrid -- Arc/Info ASCII Grid No Value Issue
Even Rouault even.rouault at mines-paris.org
Mon Jun 14 17:23:27 EDT 2010
David,
the issue was in the GXF driver that returns the nodata value as a double
precision real, but the pixel data as single precision real. So when
translating to AAIGrid, you can see the difference in precisions.
In trunk (r19868), I've made 2 changes :
* cast nodata value to float to be consistant with precision of pixel data
* add a GXF_DATATYPE configuration option that can be set to Float64 to get
full precision for nodata value and pixel values.
Best regards,
Even
Le Monday 14 June 2010 21:16:41 David Baker (Geoscience), vous avez écrit :
> All,
> Using OpenEV from FWTools version 2.4.7 to convert the GXF file found at
> http://pubs.usgs.gov/of/2000/ofr-00-0042/data/ from the GXF format to
> AAIGrid format I have found an issue.  In the GXF file the #DUMMY
> value/string is -1e32 and this is the same value/string found in the data
> portion of the GXF file.  After conversion in the AAIGrid file, the NODATA
> line reads
> NODATA_value -1.0000000000000001e+032
> but the value -1.0000000331813535e+032 is found in the data portion of the
> AAIGrid file where the value -1.0000000000000001e+032 should be found.  As
> OpenEV uses GDAL/OGR to do the conversion I have posted this issue here.
> Thanks,
> David M. Baker
> Senior Geologist - Chief Technology Advisor
> Chesapeake Energy Corporation
> 405-935-3715 office
> 405-496-5373 cell
> david.m.baker at chk.com<mailto:david.m.baker at chk.com>
> ________________________________
> This email (and attachments if any) is intended only for the use of the
> individual or entity to which it is addressed, and may contain information
> that is privileged, confidential and exempt from disclosure under
> applicable law. If the reader of this email is not the intended recipient,
> or the employee or agent responsible for delivering this message to the
> intended recipient, you are hereby notified that any dissemination,
> distribution or copying of this communication is strictly prohibited. If
> you have received this communication in error, please notify the sender
> immediately by return email and destroy all copies of the email (and
> attachments if any).
