[gdal-dev] Proper parameters for GDALBeginAsyncReader() for RGB images
Zermeno, Robert J CIV NAVAIR, 472100D robert.zermeno at navy.mil
Thu Jun 17 11:03:18 EDT 2010
Thanks Frank!
It made a lot of sense.  My last comment concerning this function is how would you be able to
Acquire a smaller image size of a larger image using GDALBeginAsyncReader() for RGB images?
I can get it to work for Grayscale, but using the same parameters for RGB gives me an AccessViolation
Error.
Example:
Example not exact:
Assume:
ImageWidth = 800
ImageHeight = 400
BufferXSize = 150
BufferYSize = 150
colorScheme = 3 (For RGB)
Bandmap[0] = 1, Bandmap[1] = 2, Bandmap[2] = 3
BYTE* JPIP_Buffer = (BYTE*)CLPMalloc(BufferXSize * BufferYSize * colorScheme)
Call to function:
GDALBeginAsyncReader(fileDataset,
	0, 0, 				//Start at top-left position
	ImageWidth, ImageHeight,	//Note, I am requesting whole image.
	JPIP_Buffer,
	BufferXSize,
	BufferYSize,
	GDT_Byte,
	colorScheme,
	Bandmap,
	0,
	0,
	0,
	0);
Under the hood, how does the function take the original image size and scale it down to fit
Into the a size much smaller than original? For some reason, when I do this for RGB color
Images, it gives a AccessViolation error when it calls GDALARGetNextUpdatedRegion().  However,
For Grayscale images, it works fine.  What would you think might be the problem?
Thanks,
Robert
-----Original Message-----
From: fwarmerdam at gmail.com [mailto:fwarmerdam at gmail.com] On Behalf Of Frank Warmerdam
Sent: Wednesday, June 16, 2010 10:05
To: Zermeno, Robert J CIV NAVAIR, 472100D
Cc: gdal-dev at lists.osgeo.org
Subject: Re: [gdal-dev] Proper parameters for GDALBeginAsyncReader() for RGB images
On Wed, Jun 16, 2010 at 12:51 PM, Zermeno, Robert J CIV NAVAIR, 472100D <robert.zermeno at navy.mil> wrote:
> Do I call GDALBeginAsyncReader() three times like RasterIO?  One call
> for Red, one for Blue, and Green?
Robert,
The AsyncReader API allows reading multiple bands in one pass, much like the RasterIO call on the GDALDataset.
> Am I correct so far?  For the Length of Buffer where I want to place
> the bytes, Should I have the parameter as  (xSize *
> GDALGetRasterCount(fileDataset) )
This is correct,
> On to
>        BufferXSize, BufferYSize,
>        JPIP_Buffer,
>        BufferXSize * colorScheme,
>        BufferYSize,
>        GDT_Byte,
>        colorScheme,
>        Bandmap,
>        0,
>        0,
>        0,
>        0);
I think the problem is your passing of BufferXSize * colorScheme.
That arguments should be the number of pixels in X, but not taking in account the number of bands.
> How is the image data stored in JPIP_Buffer. Whould it be:
> 1.rgbrgbrgbrgb
> 2.rrrrggggbbbb
> 3.bgrbgrbgrbgr
By default (if all zero for the interleaving options) the image will be returned in band sequential form.  So option '2' above.
Best regards,
Type: application/x-pkcs7-signature
Desc: not available
Url : http://lists.osgeo.org/pipermail/gdal-dev/attachments/20100617/d425c4e4/smime.bin
