[gdal-dev] Re: ESRI file geodatabase support
Duarte Carreira DCarreira at edia.pt
Fri Jun 18 11:44:00 EDT 2010
Well, I'm sold. What you need to do it??
Duarte
De: Ragi Burhum [mailto:ragi at burhum.com]
Enviada: sexta-feira, 18 de Junho de 2010 16:31
Para: Peter J Halls
Cc: Duarte Carreira; gdal-dev at lists.osgeo.org; Eric Wolf; Matt Wilkie
Assunto: Re: [gdal-dev] Re: ESRI file geodatabase support
This is meant to be an export/import type of thing. So you won't be able to "open" something in ArcMap and start manipulating it live using the ArcMap/ArcCatalog tools. The other approach I am proposing would be OGR as a seamless datasource that integrates with ArcGIS at the data access layer level. It would be transparent to the other tools.
- Ragi
On Fri, Jun 18, 2010 at 5:49 AM, Peter J Halls <P.Halls at york.ac.uk<mailto:P.Halls at york.ac.uk>> wrote:
And ... I think I may have found the file geodatabase documentation promised ...  in the  online ArecGIS 10 documentation, Administrator Library, Architecture of a geodatabase, Geodatabase XML.  It would appear that, in addition to the XML Schema they published several years ago, the XML documentation has been augmented with a view to interoperability being achieved at the XML level.  So, maybe no, they have not published the binary structure but they may have published enough to enable XML exchange.  I've not read all the material - and I would need to think about much of it before I understood it.  Whether there is enough there I cannot say ...  I was looking at
http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html
Best wishes,
Peter
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20100618/06aa265c/attachment.html
