[gdal-dev] How to use CPLPrintTime ?
EduRam eduardo.ramalho at gmail.com
Tue Jun 22 13:11:27 EDT 2010
Hi again!
I found that "gdalhttp.cpp" logs messages with CPLDebug() function.
Inside that I found that if CPL_TIMESTAMP is set, then a time stamp is also
printed.
But the time does not have milliseconds precision.
Is it possible to change that time format ?
Thanks,
Edu
View this message in context: http://osgeo-org.1803224.n2.nabble.com/gdal-dev-How-to-use-CPLPrintTime-tp5209593p5209862.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
