[gdal-dev] svn update problem with pcidsk
Even Rouault even.rouault at mines-paris.org
Thu Jun 24 19:36:43 EDT 2010
Matt,
you're not doing anything wrong. that directory used to be a svn:external but
this has changed in trunk a few months ago
Just rm -rf frmts/pcidsk/sdk
and svn update again
Le Friday 25 June 2010 01:20:13 Gregory, Matthew, vous avez écrit :
> Hi all,
> Frank Warmerdam wrote on March 12:
> > For a few months now the gdal/frmts/pcidsk/sdk directory has been
> > referenced from the pcidsk sdk subversion using svn:externals in
> > GDAL trunk.  This had the benefit of ensuing the latest pcidsk code was
> > always used with GDAL trunk.  However, it has had some downsides too.
> > Anyways, the problem are not insurmountable, but on balance I think
> > the benefits of using svn:external are outweighed by hassles and so I
> > have gotten rid of the svn:external and done an svn copy of the sdk
> > into the GDAL trunk.   I will refresh it periodically.
> I hadn't updated from SVN for a while, but when I tried today, I got this
> message:
>   svn: URL 'https://svn.osgeo.org/gdal/sandbox/warmerdam/pcidsk/src' of
>   existing directory 'frmts\pcidsk\sdk' does not match expected URL
>   'https://svn.osgeo.org/gdal/trunk/gdal/frmts/pcidsk/sdk'
> I'm guessing it's something that I'm doing incorrectly.  I'm not totally
> clear on the implications of svn:external, but is there a setting I need to
> tweak on my side?
> thanks, matt
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
