[gdal-dev] gdalwarp large imagery
GeoSpatial - Kevin gs.kevin1 at gmail.com
Fri Jun 25 03:30:13 EDT 2010
Hi all,
I am trying to re-project a very large image (size 40,000 by 40,000 pixels,
resolution ~120m) located at high latitudes (60N) to a standard wgs84. By
searching some previous posts, I come up with the following command:
gdalwarp  -of EHdr -t_srs EPSG:4326 -tr 0.001111 0.001111 --config
GDAL_CACHEMAX 200 -wm 200 -wo SKIP_NOSOURCE=YES -r bilinear -multi
input_ice.tif output_ice.tif
it is working now but the speed is very slow - likely this will take 12
hours... Any way to speed up or am I wrong in selecting the parameters? Many
thanks.
Kevin
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20100625/31534c29/attachment.html
