[gdal-dev] RE: can't open HDF5 subdatasets
benbendor dor_ben2000 at hotmail.com
Fri Jun 25 05:41:27 EDT 2010
Hello£º
I do not want to receive the mail which temporarily at present comes from  gdal-dev-request at lists.osgeo.org.
Thanks so much.
bendor
To: gdal-dev at lists.osgeo.org
Subject: can't open HDF5 subdatasets
Date: Mon, 15 Mar 2010 10:13:49 +0800
Hello:
I think is woking well by using GDALINFO to  open hdf5 image,like this:
   I:\gdalinfo Z_SATE_C_BAWX_20100129130049_P_FY3A_MERSI_GBAL_L1_20100129_0115
_0250M_MS.h5
Driver: HDF5/Hierarchical Data Format Release 5
Files: Z_SATE_C_BAWX_20100129130049_P_FY3A_MERSI_GBAL_L1_20100129_0115_0250M_MS.
h5
Size is 512, 512
Coordinate System is `'
Subdatasets:
  SUBDATASET_1_NAME=HDF5:"Z_SATE_C_BAWX_20100129130049_P_FY3A_MERSI_G   BAL_L1_20100129_0115_0250M_MS.h5"://BB_DN_average
SUBDATASET_1_DESC=[5x8000] //BB_DN_average (32-bit floating-point)
  SUBDATASET_2_NAME=HDF5:"Z_SATE_C_BAWX_20100129130049_P_FY3A_MERSI_GBAL_L1_20100129_0115_0250M_MS.h5"://EV_250_Emissive
SUBDATASET_2_DESC=[8000x8192] //EV_250_Emissive (16-bit unsigned integer)
  SUBDATASET_3_NAME=HDF5:"Z_SATE_C_BAWX_20100129130049_P_FY3A_MERSI_GBAL_L1_20100129_0115_0250M_MS.h5"://EV_250_RefSB_b1
SUBDATASET_3_DESC=[8000x8192] //EV_250_RefSB_b1 (16-bit unsigned integer)
Corner Coordinates:
Upper Left  (    0.0,    0.0)
Lower Left  (    0.0,  512.0)
Upper Right (  512.0,    0.0)
Lower Right (  512.0,  512.0)
Center      (  256.0,  256.0)
 but wen I trying to open a subdataset ,it's can't work well,why?
I:\gdalinfo HDF5:"Z_SATE_C_BAWX_20100129130049_P_FY3A_MERSI_GBAL_L1_2010012
9_0115_0250M_MS.h5"=BB_DN_average
ERROR 4: `HDF5:Z_SATE_C_BAWX_20100129130049_P_FY3A_MERSI_GBAL_L1_20100129_0115_0
250M_MS.h5=BB_DN_average' does not exist in the file system,
and is not recognised as a supported dataset name.
gdalinfo failed - unable to open 'HDF5:Z_SATE_C_BAWX_20100129130049_P_FY3A_MERSI
_GBAL_L1_20100129_0115_0250M_MS.h5=BB_DN_average'.
regards
ben
ÁÄÌì+ËÑË÷+ÓÊÏä ÏëÒªÇáËɳöÓÎ,ÊÖ»úMSN°ïÄã¸ã¶¨! Á¢¿ÌÏÂÔØ£¡
_________________________________________________________________
ÏëÖªµÀÃ÷ÌìÌìÆøÈçºÎ£¿±ØÓ¦¸æËßÄ㣡
http://cn.bing.com/search?q=%E5%A4%A9%E6%B0%94%E9%A2%84%E6%8A%A5&form=MICHJ2
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20100625/7a8e0845/attachment-0001.html
