[gdal-dev] The type initializer for 'OSGeo.GDAL.GdalPINVOKE' threw an exception. when gdal.Allregister() calls
Tamas Szekeres szekerest at gmail.com
Fri Jun 25 10:43:40 EDT 2010
What kind of exception has been thrown? Perhaps a missing dll may cause like
this.
Tamas
2010/6/25 mail2vajram <mail2vajram at gmail.com>
> i installed fwtols2.4.7 previously.That time i worked  with gdal with out
> any
> problem but now when i work with gdal it throws the following
> exception.....why. how to fix this.
> This is the way i used.....
> [DllImport("kernel32.dll", CharSet = CharSet.Auto, SetLastError = true)]
>        public static extern bool SetEnvironmentVariable(string lpname,
> string lpvalue);
>        string GDAL_HOME = @";C:\Program Files\FWTools2.4.7\bin";
> string path = Environment.GetEnvironmentVariable("PATH");
>            path += ";" + GDAL_HOME;
>            SetEnvironmentVariable("PATH", path);
>            Gdal.AllRegister();
> help me thank you....
> http://osgeo-org.1803224.n2.nabble.com/The-type-initializer-for-OSGeo-GDAL-GdalPINVOKE-threw-an-exception-when-gdal-Allregister-calls-tp5220732p5220732.html
> Sent from the GDAL - Dev mailing list archive at Nabble.com.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20100625/a7602ac7/attachment.html
