[gdal-dev] Getting error with gdaladdo on Tiff files
Sat Jun 26 19:18:34 EDT 2010
On Sat, Jun 26, 2010 at 6:41 PM, Stephen Woodbridge
<woodbri at swoodbridge.com> wrote:
> Hi all,
> I have a few Spot image files and ran the following. Is there a good way to
> check the integrity of the original image. Should I have used some other
> options?
Steve,
I imagine the problem is due to a broken system libtiff.  You
can check the integrity of the original file using:
  gdalinfo -checksum file1.tif
I would suggest trying to rebuild GDAL using the internal libtiff.  The
system libtiff often has subtle issues with overview building which
requires zipping back and forth between the base and overview
image when doing io.
Best regards,
