[gdal-dev] Geotiff AREA_OR_POINT
Gillian WALTER GWALTER at mdacorporation.com
Mon Jun 28 18:12:27 EDT 2010
I'm trying to wrap my head around Geotiff's AREA_OR_POINT=Area versus AREA_OR_POINT=Point, and how that translates into GDAL.  I've  read the "PixelIsPoint Raster Space" and "PixelIsArea Raster Space" sections of the geotiff spec, and tried to find previous posts on the topic with very limited success ( http://osgeo-org.1803224.n2.nabble.com/GRASS-Problem-importing-geotiff-with-r-in-gdal-td1879130.html ).  Am I correct in interpreting this post to mean that the pixel-is-area and pixel-is-point tiffs are read the exact same way by GDAL, with the only difference being in the value of the AREA_OR_POINT metadata key?  Should viewers then be looking for the "AREA_OR_POINT" key in addition to the georeferencing information, and shift the display to center the top-left pixel on (0,0) if it's set to Point?
Thanks,
Gillian Walter
Software Developer
Geospatial Services Inc.
57 Auriga Drive - Suite 201
Ottawa, ON K2E 8B2
Telephone:  (613) 727-1087 #245
Facsimile:  (613) 727-5853
Email:  gwalter at mdacorporation.com
This e-mail and any attachments are intended solely for the use of the intended recipient(s) and may contain legally privileged, proprietary and/or confidential information.  Any use, disclosure, dissemination, distribution or copying of this e-mail and any attachments for any purposes that have not been specifically authorized by the sender is strictly prohibited.  If you are not the intended recipient, please immediately notify the sender by reply e-mail and permanently delete all copies and attachments.  The entire content of this e-mail is for "information purposes" only and should not be relied upon by the recipient in any way unless otherwise confirmed in writing by way of letter or facsimile.
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20100628/815c03bf/attachment.html
