[gdal-dev] OpenDWG, Open Design Alliance
Andreas Neumann a.neumann at carto.net
Tue Jun 29 07:56:23 EDT 2010
Hi Frank,
Thanks for the info - do you have a pointer to this OS DWG effort?
Andreas
On Tue, June 29, 2010 12:29 pm, Frank Warmerdam wrote:
> On Tue, Jun 29, 2010 at 12:23 PM, Andreas Neumann <a.neumann at carto.net>
> wrote:
>> Hi,
>> >From time to time it would be nice if I could read DWG files from
>> OS-GIS.
>> OGR has the option to read DWG through the Open Design Alliance
>> DWGdirect
>> library - which is only available for registered users.
>> For inhouse use it would be affordable for me to become a ODA member.
>> Before I would try to do so - can I ask if someone on this list has
>> experiences with the library? Does it still work with the current gdal
>> trunk? Is it worth the efforts?
> Andreas,
> I have not attempted to maintain this driver for some time,
> and I suspect there have been changes in the dwgdirect
> library that may be a problem.  If you try it, I'm sure we would
> appreciate a report.
> I would also note there is a new open source dwg effort
> ongoing and that as that matures we might be able to
> utilize that.
> Best regards,
> I set the clouds in motion - turn up   | Frank Warmerdam,
> warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush    | Geospatial Programmer for Rent
Andreas Neumann
http://www.carto.net/neumann/
http://www.svgopen.org/
