Re: [gdal-dev] first time gdal-java exception
Ivan Lucena ivan.lucena at pmldnet.com
Tue Jun 29 14:22:18 EDT 2010
Hi there.
Did you initialize the driver manager?
Example: http://trac.osgeo.org/gdal/browser/trunk/gdal/swig/java/apps/GDALGrid.java#L521
Regards,
Ivan
>  -------Original Message-------
>  From: ahmet temiz <ahmettemiz88 at gmail.com>
>  To: gdal-dev <gdal-dev at lists.osgeo.org>
>  Subject: [gdal-dev] first time gdal-java exception
>  Sent: Jun 29 '10 13:14
>  hello
>  when I  tried gdal-java in first time, I got this exception:
>  "Exception in thread "main" java.lang.UnsatisfiedLinkError:
>  org.gdal.ogr.ogrJNI.wkb25Bit_get()I"
>  here is the code fragment that gives the exception:
>  Geometry lr1 = new Geometry(ogr.wkbLinearRing, null, null, null);
>  lr1.AddPoint_2D(0, 0);
>  lr1.AddPoint_2D(10, 10);
>  lr1.AddPoint_2D(10, 0);
>  Geometry pol1 = new Geometry(ogr.wkbPolygon, null, null, null);
>  pol1.AddGeometry(lr1);
>  might this exception have to do with my having generated gdal-java
>  from "rpm" for ubuntu?
>  do you recommend me another way  to get gdal-java for ubuntu ?
>  regards
>  _______________________________________________
>  gdal-dev mailing list
>  http://lists.osgeo.org/mailman/listinfo/gdal-dev
