[gdal-dev] Transform not working
Jamie Lahowetz deadpickle at gmail.com
Mon Mar 1 13:54:36 EST 2010
I'm new to GDAL and am usingthe python bindings. I want to transform a newly
created shapefile from WGS84 to a Lambert Conical Conformal so that I can
calculate the length of the contained polylines. The script exits with no
errors but when I look at the shapefile in arcCatalog I see that the
projection is still WGS84. Any ideas? Also, is there a way to calculate the
length directly from GDAL? Thanks.
import os
try:
    from osgeo import ogr
    from osgeo import osr
except:
    import ogr
    import osr
#~ start driver
driver = ogr.GetDriverByName('ESRI Shapefile')
#~ set workspace
ws = 'C:\\Users\\deadpickle\\
Desktop\\case study\\verify\\'
os.chdir(ws)
#~ check if it exists
if os.path.exists('test.shp'):
    driver.DeleteDataSource('test.shp')
#~ create a new shp
ds = driver.CreateDataSource('test.shp')
#~ create spatref for new shp
source = osr.SpatialReference()
source.SetFromUserInput('WGS84')
#~ create a new data layer
layer = ds.CreateLayer('test',geom_type=ogr.wkbLineString,srs=source)
#~ add an id field
fieldDefn = ogr.FieldDefn('id', ogr.OFTInteger)
layer.CreateField(fieldDefn)
#~ create a geometry
line = ogr.Geometry(ogr.wkbLineString)
#~ get the def of the layer, scheme
featureDefn = layer.GetLayerDefn()
# create a new feature
feature = ogr.Feature(featureDefn)
#~ Read 2006track file
file = open("2006track.csv","r")
file.readline()
lnlist = file.readlines()
for lines in lnlist:
    value = lines.split(",")
    if float(value[1]) == 2:
        print value
        line.AddPoint(float(value[3]),float(value[2]))
        #~ set the field 'ID'
        feature.SetField('id', float(value[1]))
#~ set the geometry for this shp
feature.SetGeometry(line)
# add the feature to the output layer
layer.CreateFeature(feature)
#~ feature = layer.GetFeature(0)
geom = feature.GetGeometryRef()
#~ change projection to lcc
target = osr.SpatialReference()
target.ImportFromProj4('+proj=lcc +lat_1= 33.000000 +lat_2=45.000000
+lat_0=39.000000 +lon_0=-96.000000 +x_0=0.0 +y_0=0.0')
coordtrans = osr.CoordinateTransformation(source, target)
geom.Transform(coordtrans)
# destroy the geometry and feature and close the data source
ds.Destroy()
line.Destroy()
feature.Destroy()
file.close()
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20100301/900e86e5/attachment.html
