[gdal-dev] Georeferencing Geostationnary (+proj=geos)
Stéphane stephane.benchimol at gmail.com
Tue Mar 2 14:12:18 EST 2010
Does anyone know if Gdal, current version or development version, is able to
translate from Geostationnary projection to other regular projection ?
Is it planned in future Gdal release ?
Many thanks !
Stéphane
2010/3/2 António Rocha <antonio.rocha at deimos.com.pt>
> Hi Stéphane
> According to http://www.gdal.org/gdal_translate.html
> *-a_ullr* /ulx uly lrx lry/:
>   Assign/override the georeferenced bounds of the output file. This
>   assigns georeferenced bounds to the output file, ignoring what would
>   have been derived from the source file.
> Yes... Regarding extracting sub-domains, I didn't tried
> Yes, please keep me in touch in case there are better methods
> Antonio
> Stéphane wrote:
>> Thanks for feedback !
>> Do you have any ideas of the meaning of -a_ullr arguments they gave you ?
>> Futhermore, once you get your GeoTiff file, did you success to translate
>> it to other projection, or extracting sub domains ?
>> I've heard that GEOS projection is not so really supported currently by
>> GDAL, and re-projection / sub domain extraction doesn't work correctly ...
>> I'll keep you in touch if any news !
>> Stéphane
>> 2010/3/2 António Rocha <antonio.rocha at deimos.com.pt <mailto:
>> antonio.rocha at deimos.com.pt>>
>>    Greetings
>>    I had exacly the same problem. I have been using LSASAF data (from
>>    MSG-2nd Generation satellites) that provides LST and FVC in HDF5
>>    files. For some technical reason they are not goerreferenced and
>>    their  information.
>>    I talked with a few ILWIS software developers and they gave the
>>    following Commands (adapted to my spatial coverage images):
>>    gdal_translate -a_srs "+proj=geos +lon_0=0.0 +h=35785831 +x_0=0.0
>>    +y_0=0.0" -a_ullr -924124.2 5421728.5 4179561.6 3468466.1
>>    "HDF5:"HDF5_LSASAF_MSG_LST_Euro_200802170100"://LST"
>>    "euro_area_georeferenced.tif"
>>    gdalwarp -s_srs "+proj=geos +lon_0=0.0 +h=35785831 +x_0=0.0
>>    +y_0=0.0" -t_srs "+proj=latlong" "euro_area_georeferenced.tif"
>>    "euro_area_latlong.tif"
>>    My HDF5 file doesn't contain any infoprmation regarding GEOS
>>    projection. So, I had to do this
>>    Hope this helps
>>    If you get any news/information/method regarding this, please let
>>    me know
>>    Best regards
>>    Antonio
>>    __________ Information from ESET NOD32 Antivirus, version of virus
>>    signature database 4907 (20100302) __________
>>    The message was checked by ESET NOD32 Antivirus.
>>    http://www.eset.com
> signature database 4908 (20100302) __________
> http://www.eset.com
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20100302/a9171b3d/attachment.html
