[gdal-dev] Problems with gdalwarp re-projecting from lat-long to Lambert Conformal
Bill Hudspeth wbhk at unm.edu
Wed Mar 3 11:44:21 EST 2010
Thanks for the input Kyle. Just a quick question. In the second
operation using gdal_translate, you indicate an -s_srs of EPSG:4326 for
the *.vrt file. Wasn't the vrt file written in the Lambert projection in
the first step? And if so, the second step could probably be done
without having to specify either s_srs or t_srs?
Is this true?
Thanks again, Bill
On Tue, 2010-03-02 at 11:36 -0700, Kyle Shannon wrote:
> Bill,
> It may be necessary to create an intermediate file that supports
> creation (I think the (rw+) flag on gdalinfo --formats shows which
> formats support create, AAIGrid supports CreateCopy() but not
> Create()).  Use gdalwarp to make a vrt file, then translate the file
> to AAIGrid:
> /usr/local/gdal/bin/gdalwarp -of VRT -s_srs EPSG:4326 -t_srs
> '+proj=lcc +lat_1=33n +lat_2=45n +lon_0=97w' mcd12_sep2109.asc
> lambert_mcd12_sep2109.vrt
> then:
> /usr/local/gdal/bin/gdal_translate -of AAIGrid -s_srs EPSG:4326 -t_srs
> '+proj=lcc +lat_1=33n +lat_2=45n +lon_0=97w' lambert_mcd12_sep2109.vrt
> lambert_mcd12_sep2109.asc
> hope that helps,
> regards,
> -Kyle
> On Tue, Mar 2, 2010 at 8:57 AM, Bill Hudspeth <wbhk at unm.edu> wrote:
>         Hello,
>         Thanks for responding. When I use gdalinfo --formats, I see
>         that AAIGrid
>         is included in the list of acceptable formats. However, when I
>         use
>         /usr/local/gdal/bin/gdalwarp -of AAIGrid -s_srs EPSG:4326
>         -t_srs
>         I get,
>         Output driver `AAIGrid' not recognised or does not support
>         direct output file creation.  The following format drivers are
>         configured
>         and support direct output:
>          VRT: Virtual Raster
>          GTiff: GeoTIFF
>          NITF: National Imagery Transmission Format
>          HFA: Erdas Imagine Images (.img)
>          ELAS: ELAS
>          MEM: In Memory Raster
>          BMP: MS Windows Device Independent Bitmap
>          PCIDSK: PCIDSK Database File
>          ILWIS: ILWIS Raster Map
>          HDF4Image: HDF4 Dataset
>          PNM: Portable Pixmap Format (netpbm)
>          ENVI: ENVI .hdr Labelled
>          EHdr: ESRI .hdr Labelled
>          PAux: PCI .aux Labelled
>          MFF: Atlantis MFF Raster
>          MFF2: Atlantis MFF2 (HKV) Raster
>          BT: VTP .bt (Binary Terrain) 1.3 Format
>          IDA: Image Data and Analysis
>          RMF: Raster Matrix Format
>         On Tue, 2010-03-02 at 08:50 +0100, Markus Neteler wrote:
>         > On Mon, Mar 1, 2010 at 7:12 PM, Bill Hudspeth <wbhk at unm.edu>
>         wrote:
>         > > When I try to re-project the exported AAIGrid to another
>         projection, I
>         > > use:
>         > > gdalwarp -s_srs EPSG:4326 -t_srs '+proj=lcc +lat__1=33n
>         +lat_2=45n
>         > > +lon_0=97w' MODIS_output_latlong.asc
>         MODIS_output_lambert.asc
>         > Note that without -of format] you generate a GeoTIFF file...
>         > > While the resultant projection information looks correct,
>         > > Driver: GTiff/GeoTIFF
>         > > The resultant text file has only the following on the top
>         line:
>         > ... it is binary, not a text file. check
>         >  gdalwarp --formats
>         > for the available formats.
>         > Markus
>         _______________________________________________
>         gdal-dev mailing list
>         gdal-dev at lists.osgeo.org
>         http://lists.osgeo.org/mailman/listinfo/gdal-dev
