[gdal-dev] transformation from WGS84 to Sphere
agnes123 agnesyipck at gmail.com
Thu Mar 4 01:51:20 EST 2010
Dear all,
i am trying to projection a shapefile from geodatic projection in WGS84
datum to geodatic projection in sphere datum by using the utility "ogr2ogr
I defined the original projection as:
'+proj=longlat +ellps=WGS84 +datum=WGS84 +no_defs'
and the target projection as :
'+proj=longlat +a=6370997 +b=6370997 +no_defs'
but the result seems no change as compare with the one in WGS84 datum. Did i
miss out something in the above projection definition or ogr2ogr does not
support the datum transformation between WGS84 and sphere?
Regards,
Agnes
View this message in context: http://n2.nabble.com/transformation-from-WGS84-to-Sphere-tp4672744p4672744.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
