[gdal-dev] error in building gdal-1.6.3 in Linux(Fedora 9)
Abhishek_Nabble shukla_abhishek at satyam.com
Thu Mar 4 08:18:19 EST 2010
 I am trying to build gdal-1.6.3 in Linux(Fedora 9).
 I am trying the following commands:
 #./configure
 #make
 #make install (not yet done)
 However, once I run make, I am getting following error:
/home/gdal-1.6.3/.libs/libgdal.so: undefined reference to
`curl_easy_perform'
`curl_easy_getinfo'
/home/gdal-1.6.3/.libs/libgdal.so: undefined reference to `curl_easy_init'
`curl_slist_append'
`curl_multi_add_handle'
/home/gdal-1.6.3/.libs/libgdal.so: undefined reference to `curl_multi_fdset'
/home/gdal-1.6.3/.libs/libgdal.so: undefined reference to `curl_multi_init'
`curl_easy_cleanup'
`curl_multi_perform'
`curl_multi_cleanup'
`curl_multi_remove_handle'
`curl_slist_free_all'
`curl_multi_info_read'
/home/gdal-1.6.3/.libs/libgdal.so: undefined reference to `curl_easy_setopt'
I am not sure what is causing the problem and how to resolve it.
In case you want to see the output of ./configure, its given below:
GDAL is now configured for i686-pc-linux-gnu
  Installation directory:    /usr/local
  C compiler:                gcc -g -O2
  C++ compiler:              g++ -g -O2
  LIBTOOL support:           yes
  LIBZ support:              external
  GRASS support:             no
  CFITSIO support:           no
  PCRaster support:          internal
  NetCDF support:            no
  LIBPNG support:            external
  LIBTIFF support:           external (BigTIFF=no)
  LIBGEOTIFF support:        internal
  LIBJPEG support:           external
  LIBGIF support:            external
  OGDI support:              no
  HDF4 support:              no
  HDF5 support:              no
  Kakadu support:            no
  JasPer support:            no
  ECW support:               no
  MrSID support:             no
  MSG support:               no
  GRIB support:              yes
  cURL support (wms/wcs/...):yes
  PostgreSQL support:        no
  MySQL support:             no
  Ingres support:            no
  Xerces-C support:          yes
  NAS support:               no
  Expat support:             yes
  ODBC support:              no
  PGeo support:              no
  OCI support:               no
  GEORASTER support:         no
  SDE support:               no
  DODS support:              no
  SQLite support:            yes
  DWGdirect support          no
  INFORMIX DataBlade support:no
  GEOS support:              no
  Old-gen python          no
  SWIG Bindings:          no
  Statically link PROJ.4:    no
  enable OGR building:       yes
  enable pthread support:    no
  hide internal symbols:     no
 Thanks in advance,
 Abhishek Shukla
View this message in context: http://n2.nabble.com/error-in-building-gdal-1-6-3-in-Linux-Fedora-9-tp4674196p4674196.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
