[gdal-dev] Re: gdal_translate not working/ windows 7 64bit?
Tamas Szekeres szekerest at gmail.com
Fri Mar 5 17:23:46 EST 2010
It works for me.
Tried with
with the following cmdline.
gdal_translate -sds sresa1b_ncar_ccsm3_0_run1_200001.nc sample.tif
Best regards,
2010/3/5 ggp08ctl <ggp08ctl at sheffield.ac.uk>
> Hi Tamas,
> Thanks for replying. Alas, I am not terribly able when it comes to binaries
> and compiling programs (hence my use of osgeo4w). I have just downloaded a
> *.nc file from another source altogether, to try. I get the same problem,
> so
> I don't think it is specific to the gebco data. The file is small and found
> here
> http://www.unidata.ucar.edu/software/netcdf/examples/sresa1b_ncar_ccsm3_0_run1_200001.nc
> if you would like to try it. I would be very interested to know whether it
> works on your pc or not.
> Best regards,
> Chris
> http://n2.nabble.com/gdal-translate-not-working-windows-7-64bit-tp4683419p4683698.html
> Sent from the GDAL - Dev mailing list archive at Nabble.com.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20100305/a412b8c1/attachment.html
