[gdal-dev] Re: gdal_translate not working/ windows 7 64bit?
Kyle Shannon ksshannon at gmail.com
Fri Mar 5 17:29:07 EST 2010
Chris,
gdal_translate requires selection of a subdataset if the NetCDF file has
more than one subdataset.  Either specify which subdataset you want, or use
-sds for all of them as Tamas did.  I don't know if that will solve your
problem.
kss
-Kyle
On Fri, Mar 5, 2010 at 3:01 PM, ggp08ctl <ggp08ctl at sheffield.ac.uk> wrote:
> Hi Tamas,
> Thanks for replying. Alas, I am not terribly able when it comes to binaries
> and compiling programs (hence my use of osgeo4w). I have just downloaded a
> *.nc file from another source altogether, to try. I get the same problem,
> so
> I don't think it is specific to the gebco data. The file is small and found
> here
> http://www.unidata.ucar.edu/software/netcdf/examples/sresa1b_ncar_ccsm3_0_run1_200001.nc
> if you would like to try it. I would be very interested to know whether it
> works on your pc or not.
> Best regards,
> Chris
> http://n2.nabble.com/gdal-translate-not-working-windows-7-64bit-tp4683419p4683698.html
> Sent from the GDAL - Dev mailing list archive at Nabble.com.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20100305/3632a25f/attachment.html
