[gdal-dev] Issues when exporting from PostGIS to shape
Peter Hopfgartner peter.hopfgartner at r3-gis.com
Wed Mar 10 06:35:05 EST 2010
Dear GDAL devs
Since I'm new to OGR, the following issues may be caused by my complete
ignorance. Anyway, the story goes like this:
I have a PostGIS tabel, like this:
CREATE TABLE impexp_shp.points (
id serial,
name varchar(80),
CONSTRAINT points_pkey PRIMARY KEY (id)
which contains the following:
INSERT INTO impexp_shp.points (name, the_geom)
VALUES
('così è, Straße, öäü ÖÄÜ è é ò ó ù ú ì í €', ST_GeomFromText('POINT(1
1)',-1));
I try to export this as a shape file:
ogr2ogr -f 'ESRI Shapefile' '/tmp/ut_table_with_geom/points'
PG:'host=postgis user=unittest dbname=unittest password=unittestx'
'impexpshp.points'
And get the attached shape file.
I have the following issues with the result:
i) The .dbf in this shape file does not contain the column "id".
ii) the resulting shape file has a language identifier set to 57 (ANSI),
but it really is UTF-8 [1][2].
GDAL is version 1.6.3. PostGIS is version 1.4.1. platform is CentOS 5,
64 bit.
Regards,
Peter
[1]
http://support.esri.com/index.cfm?fa=knowledgebase.techArticles.articleShow&d=21106
[2] http://www.dbase.com/knowledgebase/int/db7_file_fmt.htm
Dott. Peter Hopfgartner
R3 GIS Srl - GmbH
Via Johann Kravogl-Str. 2
I-39012 Meran/Merano (BZ)
Email: peter.hopfgartner at r3-gis.com
Tel. : +39 0473 494949
Fax  : +39 0473 069902
www  : http://www.r3-gis.com
XING : http://www.xing.com/go/invita/8917535
Type: application/zip
Desc: not available
Url : http://lists.osgeo.org/pipermail/gdal-dev/attachments/20100310/1d6ba147/points.zip
