[gdal-dev] Compilation issues with gdal/ecw.
marc sintsixtus at gmail.com
Wed Mar 10 13:23:53 EST 2010
Hello,
I'm on Ubuntu 9.10/jaunty.
I have the combo "gdal-1.7.1/libecwj2-3.3"
gcc -v
Using built-in specs.
Target: i486-linux-gnu
Configured with: ../src/configure -v --with-pkgversion='Ubuntu
4.4.1-4ubuntu9' --with-bugurl=file:///usr/share/doc/gcc-4.4/README.Bugs
--enable-languages=c,c++,fortran,objc,obj-c++ --prefix=/usr
--enable-shared --enable-multiarch --enable-linker-build-id
--with-system-zlib --libexecdir=/usr/lib --without-included-gettext
--enable-threads=posix --with-gxx-include-dir=/usr/include/c++/4.4
--program-suffix=-4.4 --enable-nls --enable-clocale=gnu
--enable-libstdcxx-debug --enable-objc-gc --enable-targets=all
--disable-werror --with-arch-32=i486 --with-tune=generic
--enable-checking=release --build=i486-linux-gnu --host=i486-linux-gnu
--target=i486-linux-gnu
Thread model: posix
gcc version 4.4.1 (Ubuntu 4.4.1-4ubuntu9)
After ecw make & install, I compile gdal. (wiith configure --with-ecw)
Then I get
make[2]: Map '/home/marc/development/gdal-1.7.1/frmts/ecw' wordt
binnengegaan
/bin/sh /home/marc/development/gdal-1.7.1/libtool --mode=compile
--tag=CXX g++ -g -O2  -Wall  -I/home/marc/development/gdal-1.7.1/port
-I/home/marc/development/gdal-1.7.1/gcore
-I/home/marc/development/gdal-1.7.1/alg
-I/home/marc/development/gdal-1.7.1/ogr
-I/home/marc/development/gdal-1.7.1/ogr/ogrsf_frmts -DFRMT_ecw
-DOGR_ENABLED -I/home/marc/development/gdal-1.7.1/port
-I/usr/local/include   -c -o ../o/ecwdataset.lo ecwdataset.cpp
libtool: compile:  g++ -g -O2 -Wall
-I/usr/local/include -c ecwdataset.cpp  -fPIC -DPIC -o
../o/.libs/ecwdataset.o
In file included from /usr/local/include/NCSDefs.h:38,
                  from /usr/local/include/NCSECWClient.h:48,
                  from vsiiostream.h:43,
                  from ecwdataset.cpp:35:
/usr/local/include/NCSTypes.h:247:2: error: #error unknown machine type
will require custom 64 bit variables
In file included from /usr/local/include/NCSECWClient.h:48,
/usr/local/include/NCSDefs.h:220:2: error: #error DEFINE SYSTEM INCLUDES
FOR TYPES
In file included from /usr/local/include/NCSJP2FileView.h:39,
                  from /usr/local/include/NCSFile.h:27,
                  from vsiiostream.h:46,
/usr/local/include/NCSMutex.h:93:2: error: #error NCSGlobalLockInfo
In file included from /usr/local/include/NCSJPCIOStream.h:30,
                  from /usr/local/include/NCSJP2Box.h:27,
                  from /usr/local/include/NCSJP2FileView.h:45,
/usr/local/include/NCSFileIO.h:132:2: error: #error - need to include
types.h and stat.h for this platform
/usr/local/include/NCSTypes.h:263: error: 'UINT32' does not name a type
/usr/local/include/NCSTypes.h:264: error: 'UINT64' does not name a type
/usr/local/include/NCSTypes.h:265: error: 'UINT64' does not name a type
/usr/local/include/NCSTypes.h:266: error: 'INT64' does not name a type
/usr/local/include/NCSTypes.h:267: error: 'INT64' does not name a type
/usr/local/include/NCSTypes.h:272: error: 'UINT32' does not name a type
In file included from vsiiostream.h:43,
etc.
1) since the source of ecw is more or less open, a bin tar.gz gdal+ecw
would be fine. (just a gdal folder where we need to do "make install")
2) a solution for this problem??  It might be a development/*.h  package??
Thanks,
Marc
What's on Shortwave guide: choose an hour, go!
http://shortwave.tk
700+ Radio Stations on SW http://swstations.tk
300+ languages on SW http://radiolanguages.tk
