[gdal-dev] question with field name read from ogrinfo
Fri Mar 12 11:51:27 EST 2010
Randy wrote:
> Hi Frank and list,
>  I have a question about field name in OGR:
> I read the “IHO transfer standard for digital hydrographic data
> publication S-57 Edition 3.1-November 2000”,and it tells me that one
> spatial record should have a “Record name” and its field name is
> [RCNM].But in ogrinfo ,it gives me a field name-“NAME_RCNM”.
> Then, I’d like to know if the ogrinfo’s writer change the field name or
> it means the [NAME_RCNM] is on the new S-57 version while [RCNM] is just
> on the old version(3.1 edition)?
Randy,
I always called this field NAME_RCNM so it isn't about what edition it is
from.  I believe it is named this because it is the RCNM extracted from
the NAME field of the feature (FSPT).  I presume it is used to lookup
the RCNM and RCID in the set of spatial records when composing the geometry
for the feature.
Best regards,
