[gdal-dev] Howto convert a CSV with geometry and a CVS without into one Geodatabase (.mdb)?
Mon Mar 15 10:47:12 EDT 2010
Stefan Keller wrote:
> Thanks for the hint, right.
> So how can I insert the point geometry attribute (called SHAPE) which
> is an OLE Object?
> Do you know the binary encoding of that?
Stefan,
I don't know the details of how to do this, but the binary format
returned from the shape column is already supported by the PGEO driver.
You could scan that to get a sense of how it works.
Best regards,
