[gdal-dev] gdalwarp with JPEG not working?
Ian Dees ian.dees at gmail.com
Tue Mar 16 10:08:38 EDT 2010
I am attempting to warp a JPG/JPW file pair to a TIFF using the following
command:
$ gdalwarp -t_srs EPSG:4326
EUSC_20100222_Portugal_Madeira_flood_Funchal01_high.jpg_warped.tif
But I'm getting the following error:
ERROR 4: `EUSC_20100222_Portugal_Madeira_flood_Funchal01_high.jpg' not
recognised as a supported file format.
When I run gdalinfo on the same file, it reads it fine and I get:
Driver: JPEG/JPEG JFIF
Files: EUSC_20100222_Portugal_Madeira_flood_Funchal09_high.jpg
       EUSC_20100222_Portugal_Madeira_flood_Funchal09_high.jgw
Size is 9934, 7016
Coordinate System is `'
Origin = (307064.001182469015475,3618798.550588979851454)
Pixel Size = (0.635000000000018,-0.635000000000014)
Metadata:
  EXIF_BitsPerSample=8 8 8
  EXIF_Compression=1
  EXIF_PhotometricInterpretation=2
  EXIF_ImageDescription=ZKI Map
  EXIF_Orientation=1
  EXIF_SamplesPerPixel=3
  EXIF_XResolution=(300)
  EXIF_YResolution=(300)
  EXIF_PlanarConfiguration=1
  EXIF_ResolutionUnit=2
  EXIF_Software=Adobe Photoshop CS2 Windows
  EXIF_DateTime=2010:02:25 15:48:31
  EXIF_Artist=German Aerospace Center (DLR), German Remote Sensing
Datacenter (DFD), Center for Satellite Based Crisis Information (ZKI)
  EXIF_Copyright=Copyright (c) German Aerospace Center (DLR), German Remote
Sensing Datacenter (DFD), Center for Satellite Based Crisis Information
(ZKI)
  EXIF_ColorSpace=65535
  EXIF_PixelXDimension=9934
  EXIF_PixelYDimension=7016
Image Structure Metadata:
  SOURCE_COLOR_SPACE=YCbCr
  INTERLEAVE=PIXEL
  COMPRESSION=JPEG
Corner Coordinates:
Upper Left  (  307064.001, 3618798.551)
Lower Left  (  307064.001, 3614343.391)
Upper Right (  313372.091, 3618798.551)
Lower Right (  313372.091, 3614343.391)
Center      (  310218.046, 3616570.971)
Band 1 Block=9934x1 Type=Byte, ColorInterp=Red
    COMPRESSION=JPEG
Band 2 Block=9934x1 Type=Byte, ColorInterp=Green
    COMPRESSION=JPEG
Band 3 Block=9934x1 Type=Byte, ColorInterp=Blue
    COMPRESSION=JPEG
Why can't gdalwarp read this file?
View this message in context: http://n2.nabble.com/gdalwarp-with-JPEG-not-working-tp4743823p4743823.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
