[gdal-dev] Geodetic Problem
David Baker (Geoscience) david.m.baker at chk.com
Tue Mar 16 19:25:40 EDT 2010
Aron,
Thanks for the info...
David
David M. Baker
Senior Geologist - Chief Technology Advisor
Chesapeake Energy Corporation
405-935-3715 office
405-496-5373 cell
-----Original Message-----
Sent: Tuesday, March 16, 2010 4:14 PM
To: David Baker (Geoscience)
Cc: gdal-dev at lists.osgeo.org
Subject: Re: [gdal-dev] Geodetic Problem
On 3/16/10, David Baker (Geoscience) <david.m.baker at chk.com> wrote:
> Frank and the List,
> I have a geodetic problem I hope GDAL/OGR can solve.
I have not seen the direct or inverse gedesic routines in either Proj
or OGR. SimGear provides an implementation here
<http://cvs.simgear.org/viewvc/source/simgear/math/SGGeodesy.cxx?root=SimGear&view=markup>
(function _geo_direct_wgs_84) and you could use OSRGetSemiMajor
OSRGetInvFlattening OSRGetSemiMinor for the "a", "rf", and "b"
variables respectively to use other ellipsoids assigned in OGR. Proj
wiki has notes here
<http://trac.osgeo.org/proj/wiki/GeodesicCalculations> which notes a
fortran implementation <http://www.ngs.noaa.gov/PC_PROD/Inv_Fwd/>.
Aron
Aron Rubin
Handy Husband & Daddy Jungle Gym & Senior Engineer
This email (and attachments if any) is intended only for the use of the individual or entity to which it is addressed, and may contain information that is privileged, confidential and exempt from disclosure under applicable law.  If the reader of this email is not the intended recipient, or the employee or agent responsible for delivering this message to the intended recipient, you are hereby notified that any dissemination, distribution or copying of this communication is strictly prohibited.  If you have received this communication in error, please notify the sender immediately by return email and destroy all copies of the email (and attachments if any).
