[gdal-dev] help compiling hdf5 option on linux
Vincent Schut schut at sarvision.nl
Mon Mar 22 04:38:32 EDT 2010
On 03/19/2010 09:56 PM, John Cartwright wrote:
> Thanks for suggestions Antonio and Vincent.  Unfortunately, neither
> --with-hdf5=/usr/local/contrib/hdf5-1.8.4/lib
> nor
> --with-hdf5=/usr/local/contrib/hdf5-1.8.4/include,/usr/local/contrib/hdf5-1.8.4/lib
> made any difference.
Hmm, then I don't know, I'm afraid. I have only experience compiling
gdal with hdf4 (for reading spot, modis), not with hdf5... You might get
some more info by checking the config.log file.
Vincent.
> --john
> On 03/18/2010 01:57 AM, Antonio Valentino wrote:
>> Hi John,
>> Il giorno Wed, 17 Mar 2010 14:22:01 -0600
>> John Cartwright<John.C.Cartwright at noaa.gov>  ha scritto:
>>> Hello All,
>>> I'm trying to get 1.7.1 compiled on a 64-bit RHEL 5 server using
>>> hdf5-1.8.4-patch1.  I have hdf5 and netcdf apparently compiled
>>> successfully and have included the following in my configure statement
>>> for gdal:
>> not sure, but maybe you should use something like
>> best regards
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
