[gdal-dev] Re: How to divide a raster layer into a set of tiles?
Christian Müller christian.mueller at nvoe.at
Mon Mar 22 16:35:58 EDT 2010
gdal_retile.py definitely creates georeferenced tiles, I developed this
utility.
I did some experiments reprojecting the single tiles while retiling, but it
simply does not work. As a consequence I canceled the reprojecting support.
The solution for your problem is:
1) Use gdal_merge to create the big image
2) reproject with gdal_warp
3) use gdal_retile to create your new tiles
I did a lot of experiments to avoid creating the big picture without
success.
Even Rouault writes:
> Le Monday 22 March 2010 19:35:47 Gilles Bassière, vous avez écrit :
>> Hi,
>> The problem with this workflow is that it creates non-georeferenced
>> tiles (I don't know if this is the intended behaviour of this command).
> gdal_retile.py *does* create georeferenced tiles. I've just verified it. What
> make you think the contrary ?
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
