[gdal-dev] Issue with ogrinfo: unixODBC and MS SQL
Gregor at HostGIS gregor at hostgis.com
Mon Mar 22 18:16:30 EDT 2010
Hey guys. A few weeks back, Chaitanya helped us out with some fixes
regarding unixODBC on 64-bit platforms, and got MapServer able to render
remote data via ODBC from PostgreSQL and MySQL. Thanks a million!
Now we're on the last step: getting OGR data sources to work when the
ODBC server is Microsoft SQL Server. Unlike MySQL and PgSQL, though, MS
SQL returns some weird binary stuff:
$ ogrinfo test.ovf
ERROR 1: No column definitions found for table
'�o��y.����y', layer not usable.
'���������.��������S', layer not usable.
'���������.���������EA', layer not
usable.
(... and so on ...)
PHP and MS SQL and ODBC get along just fine as long as I set my ODBCINI
and FREETDSCONF files, and make sure to use a DSN instead of a DSN-less
connection string. I can use the isql program and connect too. So the
basic unixODBC and MS SQL layers seem to be working okay.
Any ideas?
The OVF is as follows:
<OGRVRTDataSource>
     <OGRVRTLayer name="dsn">
         <SrcDataSource>ODBC:user/pass at dsn</SrcDataSource>
         <SrcLayer>cities</SrcLayer>
         <GeometryType>wkbPoint</GeometryType>
         <LayerSRS>WGS84</LayerSRS>
         <GeometryField encoding="PointFromColumns" x="x" y="y"/>
     </OGRVRTLayer>
</OGRVRTDataSource>
The odbc.ini is:
[dsn]
Driver  = Microsoft SQL Server
Server  = ec2-A-B-C-D.compute-1.amazonaws.com
Port    = 1433
Database = testing
TDS_Version = 7.0
The freetds.conf is:
[global]
tds version = 7.0
text size = 64512
[dsn]
host = ec2-A-B-C-D.compute-1.amazonaws.com
port = 1433
HostGIS, Open Source solutions for the global GIS community
Greg Allensworth - SysAdmin, Programmer, GIS Person, Security
    Network+   Server+   A+   Security+   Linux+
    PHP   PostgreSQL   MySQL   DHTML/JavaScript/AJAX
"No one cares if you can back up — only if you can recover."
