[gdal-dev] GDAL custom build (ECW required)
Gilles Bassière gbassiere at gmail.com
Tue Mar 23 11:40:45 EDT 2010
Hi (again),
I'm facing problems with GeoTiff compression on a custom build of GDAL.
My source dataset is a virtual raster composed of ECW tiles built with:
 gdalbuildvrt ortho-dept04-2004-la2e.vrt ortho-dept04-2004-la2e/*.ecw
The error comes when I try to extract and reproject some portions of
this virtual raster with gdalwarp. With no compression, everything runs
fine but I get huge GeoTiffs. Problems arise with compression:
with COMPRESS=JPEG:
 Creating output file that is 10000P x 10000L.
 Processing input file ortho-dept04-2004-la2e.vrt.
 0...10...20...30..gdalwarp: tif_jpeg.c:691: JPEGPreDecode: Assertion
`sp->cinfo.comm.is_decompressor' failed.
 Aborted
with COMPRESS=DEFLATE:
 0...10...20...30...40...50...60...70...80...90ERROR 1:
ZIPDecode:ortho-dept04-2004-lam93-tif/04-2004-0895-6290-lam93.tif:
Decoding error at scanline 0, incorrect header check
 ERROR 1: TIFFReadEncodedTile() failed.
 ...100 - done.
with COMPRESS=LZW:
 0...10...20...30...40...50...60...70...80...90Segmentation fault
In the case of JPEG, the error appears randomly (most files are created
with no error) but in the cases of LZW and DEFLATE, it happens every
time and always after the 90% mark.
The command used was:
 gdalwarp -s_srs "+init=epsg:27572" -t_srs "+init=epsg:2154" \
    -te $e -ts 10000 10000 -co COMPRESS=LZW -co TILED=YES \
    -co BLOCKXSIZE=512 -co BLOCKYSIZE=512 ortho-dept04-2004-la2e.vrt \
    ortho-dept04-2004-lam93-tif/04-2004-$x-$y-lam93.tif
My system is Ubuntu Jaunty (9.04) and all dependencies where installed
with the package manager (including -dev packages). I've built libecw
and gdal from source with the following commands:
# Build libecw
DEST=`pwd`
cd ../src/libecwj2-3.3/
./configure --prefix=$DEST
make -j2
mkdir $DEST/include
make install
# Build GDAL
cd ../gdal-1.7.1/
./configure --prefix=$DEST --with-ecw=$DEST --with-python
make -j2
source ../../env/gdal/bin/activate # virtualenv for Python bindings
make install
deactivate
# Register libs in $DEST/lib
sudo ldconfig
Because of ticket #3139 [1], I suspect something wrong with my build but
I don't know what. Any help would be much appreciated.
Thanks in advance
[1] https://trac.osgeo.org/gdal/ticket/3139
Gilles Bassière - Web/GIS software engineer
http://gbassiere.free.fr/
