[gdal-dev] Re: Gdal / Python / Win7 crash with ReadAsArray()
NopMap ekkehart at gmx.de
Tue Mar 23 17:23:53 EDT 2010
Hi!
Eventually I had some time to look into this again.
First thing I tried is updating python to 2.6.5 - no change, still crashes.
Then I tried running exactly the same files in a 32bit XP virtual machine.
It works there. This is a workaround, but not a solution as I cannot run the
whole workflow there.
It seems that this is a Windows7 64bit specific problem.
What is the proper procedure to file a bug report for GDAL?
bye
          Nop
View this message in context: http://n2.nabble.com/Gdal-Python-Win7-crash-with-ReadAsArray-tp4398401p4787310.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
