[gdal-dev] Re: Gdal / Python / Win7 crash with ReadAsArray()
Tamas Szekeres szekerest at gmail.com
Tue Mar 23 17:55:37 EDT 2010
You didn't mention whether you are running against the x64 version of
python.exe or the x86 version?
I also see a problem when running the x64 version of python with numpy
installed could crash gdal (x64), however without installing numpy it should
work properly.
> It seems that this is a Windows7 64bit specific problem.
If you could do a test with the binaries provided at
http://vbkto.dyndns.org/sdk/  that would be helpful. It seems the python
auto-tests are working well with these packages on a Win2003 Server x64
platform.
What is the proper procedure to file a bug report for GDAL?
Obtain an osgeo userid and submit a ticket in the GDAL trac:
http://trac.osgeo.org/gdal/
Best regards,
Tamas
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20100323/bc105526/attachment-0001.html
