[gdal-dev] field name in ESRI file
Peter J Halls P.Halls at york.ac.uk
Wed Mar 24 11:15:02 EDT 2010
Oz,
   shapefiles use the dBase IV format .dbf file for attributes: this defines the
maximum field name width to be 10 characters - 'LAND USE CODE' has 13.  Also,
space characters are not permitted - use underscore '_' instead.  Whilst GDAL
may create the field names as you have specified, other packages may not accept
them as input.  I believe that the Shapefile rules are still available as a
White Paper on the ESRI.com website: it is worth reading the document to
understand what is possible.
Best wishes,
Peter
Oz Nahum wrote:
> Hello GDAL Devs,
> I encoutered a small problem, where I don't understand why field names in
> ESRI Shape files created by gdal, are truncated.
> Here is a code snippet:
>     field_LUC = ogr.FieldDefn()
>     field_LUC.SetName('LAND USE CODE')
>     field_LUC.SetType(ogr.OFTInteger)
>     field_LUC.SetWidth(15)
>     dst_layer.CreateField(field_LUC)
> Yet, when I examine the output file the attribute table contains  a field
> called "LAND USE C",
> so 3 characters are missing.
> Would be happy to know what am I doing wrong. Thank you very much,
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Peter J Halls, GIS Advisor, University of York
Telephone: 01904 433806     Fax: 01904 433740
Snail mail: Computing Service, University of York, Heslington, York YO10 5DD
This message has the status of a private and personal communication
