[gdal-dev] OGR Feature style API changes: StyleTable on datasources and layers
Chaitanya kumar CH chaitanya.ch at gmail.com
Thu Mar 25 13:32:39 EDT 2010
Brian,
I cannot say much about the style tables. But, I would like to know about
the constants for the TestCapability() methods.
On Thu, Mar 25, 2010 at 9:09 PM, brian <rush at winkey.org> wrote:
> I have two issues with the datasource and layer methods to get and set
> style tables.
> 1) The GetStyleTable(), SetStyleTableDirectly(), and SetStyletable()
> methods are not virtual therefore only the memory driver can use them.
> 2) The SetStyleTableDirectly() and SetStyletable() methods both return
> void. it is plausable that a datasource or layer could not support them.
> The API changes i am proposing are.
> 1) make the GetStyleTable(), SetStyleTableDirectly(), and
> SetStyletable() methods virtual.
> 2) make the SetStyleTableDirectly() and SetStyletable() methods return
> OGRErr.
> If a layer or datasource does not have a style table the GetStyleTable()
> method would already return NULL.
> I am also wondering if it makes any sence to add a couple of constants
> Any feedback would be appreciated.
> Brian
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Best regards,
Chaitanya kumar CH.
/tʃaɪθənjə/ /kʊmɑr/
+91-9848167848
17.2416N 80.1426E
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20100325/559ce4dc/attachment.html
