[gdal-dev] Adding multipolygons to an existing geometry collection
Even Rouault even.rouault at mines-paris.org
Thu Mar 25 14:16:31 EDT 2010
> What's the "Java dirty trick" that the code talks about?
Ari,
Do you really want to hear the explanation ;-) ? OK, here it is.
This is related to subtelities of SWIG and Java garbage collection.
Imagine that DISOWN is still used for the input parameter of
ForceToMultiPolygon
Consider the following code :
geom1 = ogr.CreateGeometryFromWKT(xxxx);
geom2 = ogr.ForceToMultiPolygon(geom1);
geom2 = null;
/* big memory allocation */
foo(geom1)
If nothing special is done, during the big memory allocation, the garbage
collector will collect the geom2 object. During its finalization, this will
call the destructor of the underlying C++ object (let's call it geom2_cpp).
But since the call of ForceToMultiPolygon(), geom1_cpp is owned by geom2_cpp,
thus deleting geom2_cpp will cause geom1_cpp to become invalid. And
foo(geom1) would operate on garbage.
This can be fixed (I have already done this for Feature.SetGeometryDirectly())
by adding special code in ogr_java.i so that geom1 (the Java object) holds a
Java reference to geom2 (the Java object). So the 2 objects are bound
together and garbage collection of one cannot occur if the other one is still
in scope...
Calling Clone() and separating the lifetime of the 2 objects avoids the above
complication.
Best regards,
Even
> Ari
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
