Re: [gdal-dev] Re: rgdal source code
Ivan Lucena ivan.lucena at pmldnet.com
Fri Mar 26 10:56:25 EDT 2010
Roger,
Yes, you are right. The source code is on  rgdal_0.6-25.tar.gz, I know, but the instructions to build on Windows are on the rgdal_0.6-25.zip package on README.windows, where it says:
The R Windows binary rgdal package is built against an FWTools Windows binary, using VC++.
Notes:
Building rgdal.dll in rgdal/src:
cl /MT /Ox /EHsc /D "WIN32" /c /I E:\rsb\R\R-2.2.1pat\include /I C:\Programfiler\FWTools1.0.0a7\incl
ude *.cpp
link /dll /out:rgdal.dll /def:RGDAL.def gdal-bindings.obj ogr_geom.obj ogr_proj.obj ogrsource.obj E:
\rsb\R\R-2.2.1pat\lib\Rdll.lib /libpath:"C:\Programfiler\FWTools1.0.0a7\lib" gdal_i.lib
So I am trying to change it a little bit in order to build against GDAL 1.7.1 (or trunk).
How does that sounds to you? Good idea?
Regards,
Ivan
>  -------Original Message-------
>  From: Roger Bivand <Roger.Bivand at nhh.no>
>  To: gdal-dev at lists.osgeo.org
>  Subject: [gdal-dev] Re: rgdal source code
>  Sent: Mar 26 '10 09:31
>  The root cause of the sourceforge issue is in a message posted 2010-03-25
>  from their admin:
>  "Update on the current CVS outage that is affecting projects whose UNIX
>  names start with the letters  a, e, h, i, m, o, r, s, w, z.
>  The work being done on this server may take up to two days to resolve. We’re
>  working to resolve this with alacrity and assure maximum stability and
>  performance."
>  So access should be back by the end of March.
>  Roger
>  Roger Bivand wrote:
>  > On Thu, 25 Mar 2010, Ivan wrote:
>  >> Roger,
>  >> I in fact did my homework, but I've got a C.
>  >> As you can see on my previous message I did find the RGDAL Source Forge
>  >> page
>  >> where it shows the CVS instructions ===> [1] <===. That would give a B+
>  >> at
>  >> least, no? If it worked.
>  >> cvs -d:pserver:anonymous at rgdal.cvs.sourceforge.net:/cvsroot/rgdal login
>  >> Logging in to
>  >> :pserver:anonymous at rgdal.cvs.sourceforge.net:2401/cvsroot/rgdal
>  >> CVS password:
>  >> cvs [login aborted]: connect to
>  >> rgdal.cvs.sourceforge.net(216.34.181.108):2401 failed: Connection refused
>  >> That was a dead end.
>  > Correct. When I tried, anonymous checkout from sourceforge was also
>  > blocked - nothing we've done, maybe something sourceforge has done. I have
>  > changed the main description to:
>  > "WARNING: rgdal is only available for download from CRAN - this repository
>  > is only used for development and browsing of source code. NEVER use the
>  > very out of date file bundles for download from this site!!! See
>  > http://rgdal.sourceforge.net for link."
>  > Short of migrating to R-forge (which I have done for another R package,
>  > spdep), there isn't much that can be done with sourceforge, I'm afraid
>  > (sourceforge isn't my favorite place to be).
>  > cc: Tim: Any idea why the anonymous checkout fails? Longer term - is
>  > migration to SVN on R-Forge worth considering?
>  > Roger
>  >> I download some of those zip packages from rgdal.sourceforge.net but they
>  >> only have binary that requires FWTools installation.
>  >> Another dead end.
>  >> But you are right I should have search a little more to find the CRAN
>  >> page.
>  >> So I am downloading rgdal_0.6-2.5.zip now. Let's see how it goes.
>  > That is the current Windows CRAN binary, get rgdal_0.6-25.tar.gz for the
>  > source. Install the Windows binary within R - do *not* treat the zip
>  > archive as an archive - it is just a frozen binary version of the source
>  > for Windows.
>  > Roger
>  >> Thanks you so very much Roger. Have a nice day.
>  >> Ivan
>  >> Roger Bivand wrote:
>  >>> Please, do your homework!
>  >>> Google on "R rgdal" gives:
>  >>> http://cran.r-project.org/web/packages/rgdal/index.html
>  >>> http://rgdal.sourceforge.net/
>  >>> where the latter says: "The R contributed package rgdal is available
>  >>> from
>  >>> CRAN", that is the first link. On CRAN you will find both the source
>  >>> tarball
>  >>> and a Windows 32-bit binary including 1.7.1 with standard drivers and
>  >>> expat
>  >>> for reading KML etc.
>  >>> The sourceforge site is used exclusively as a CVS repository for
>  >>> developers
>  >>> - it hasn't been used for software distribution since about 2004; the
>  >>> CRAN
>  >>> distribution mechanism is far more robust and "just works".
>  >>> Refer to show.file(system.file("README.windows", package="rgdal")) if
>  >>> you
>  >>> need to build from source for more exotic drivers.
>  >>> The relevant mailing list is R-sig-geo,
>  >>> https://www.stat.math.ethz.ch/mailman/listinfo/R-SIG-Geo/, and the best
>  >>> point of entrance, the R Spatial task view:
>  >>> http://cran.r-project.org/web/views/Spatial.html.
>  >>> Hope this helps,
>  >>> Roger
>  >>> Ivan-5 wrote:
>  >>>> Hi there,
>  >>>> I am trying to get RGDAL to work with GDAL 1.7.1 but I cannot access
>  >>>> the
>  >>>> source code [1] and the binaries for Windows depend on some old version
>  >>>> of
>  >>>> gdal_fw.dll. Does anybody have any clue?
>  >>>> Regards,
>  >>>> Ivan
>  >>>> [1] - http://sourceforge.net/scm/?type=cvs&group_id=84716
>  >>>> _______________________________________________
>  >>>> gdal-dev mailing list
>  >>>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
>  >>> Roger Bivand
>  >>> Economic Geography Section
>  >>> Department of Economics
>  >>> Norwegian School of Economics and Business Administration
>  >>> Helleveien 30
>  >>> N-5045 Bergen, Norway
>  > Roger Bivand
>  > Economic Geography Section, Department of Economics, Norwegian School of
>  > Economics and Business Administration, Helleveien 30, N-5045 Bergen,
>  > Norway. voice: +47 55 95 93 55; fax +47 55 95 95 43
>  > e-mail: Roger.Bivand at nhh.no
>  Roger Bivand
>  Helleveien 30
>  View this message in context: http://n2.nabble.com/gdal-dev-rgdal-source-code-tp4799954p4804208.html
>  Sent from the GDAL - Dev mailing list archive at Nabble.com.
