[gdal-dev] Converting contour lines (Shape files) into DEM
    Even Rouault
    even.rouault at mines-paris.org
    Sat Mar 27 18:07:24 EDT 2010
Kishore,
Here is a process you could try:
1) Prepare an output GDAL file for gdal_rasterize.
You can take care inspiration of
http://trac.osgeo.org/gdal/wiki/FAQRaster#HowcanIcreateablankrasterbasedonavectorfilesextentsforusewithgdal_rasterizeGDAL1.8.0
Modify it to create 1 band (instead of 4) and for step 3) to work, you should
take care of setting a nodata value on the output file and initialize the
raster with it:
dst_ds.GetRasterBand(1).SetRasterNoDataValue(0)
dst_ds.GetRasterBand(1).Fill(0)
(if you can compile GDAL from source, you can avoid this step by grabbing the
latest sources that have an enhanced version of gdal_rasterize, directly able
to create the output file . See http://trac.osgeo.org/gdal/ticket/3505)
2) Use gdal_rasterize to burn the contour lines.
See http://gdal.org/gdal_rasterize.html
3) Fill the holes (the nodata values) with gdal_fillnodata.py.
See http://gdal.org/gdal_fillnodata.html
Now, the result should be usable with gdaldem.
Best regards,
Even
Le Saturday 27 March 2010 19:09:06 Kishore Reddy, vous avez écrit :
> Hi everyone,
> I am planing to use gdaldem to create relief shaded maps. But the
> problem is gdaldem takes only DEM files as input. Unfortunately I have
> contour lines (in the form of Shape files). So is there any way
> (command line) to convert these shape files into DEM files?
> Kishore
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
