[gdal-dev] Commit r19248
Ari Jolma ari.jolma at gmail.com
Mon Mar 29 15:24:55 EDT 2010
Even Rouault wrote:
> Andrey,
> r19248 introduce Python specific code in general .i files. The consequence is
> that it breaks the Perl bindings (see
> http://buildbot.osgeo.org:8500/builders/telascience-quick/builds/312/steps/perl-make/logs/stdio).
> It also breaks Python3 compatibility as PyString_FromStringAndSize and
> PyString_AsString aren't available (though this could be fixed easily by
> using PyBytes_FromStringAndSize and PyBytes_AsString with a #if
> PY_VERSION_HEX >= 0x03000000)
> I think the new implementation should be done only inside a #if
> defined(SWIGPYTHON) I guess, and the old implementation preserved for other
> binding languages.
I can't see what's the problem that r19248 attempts to solve - I must
admit that I don't understand everything that goes on in the read/write
bindings. Does PyBytes_FromStringAndSize make a copy of the binary data?
Is that the "unnecessary string copying"? I don't think there is such a
problem in the Perl bindings. Maybe an enhancement request ticket and a
bit of discussion would have been a good thing to start with.
Best regards,
Ari
> Best regards
> Even
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
