[gdal-dev] Contours from the python interface
Tue Mar 30 08:33:05 EDT 2010
Martin Raspaud wrote:
> -----BEGIN PGP SIGNED MESSAGE-----
> Hash: SHA1
> Hi,
> I rebound on the previous contour thread to ask if it is possible to burn
> contours/borders into raster programatically with python ?
Martin,
Yes. The gdal_fillnodata.py utility is just a python script,and you can examine
it to see how to call the fillnodata algorithm.  The gdal_rasterize utility
is a program, but the algorithm is also exposed in python (with some loss of
flexibility) and it can be seen in use in the test script at:
   http://svn.osgeo.org/gdal/trunk/autotest/alg/rasterize.py
Good luck,
