[gdal-dev] Commit r19248
Andrey Kiselev dron at ak4719.spb.edu
Wed Mar 31 09:07:48 EDT 2010
On Tue, Mar 30, 2010 at 08:25:07PM +0300, Ari Jolma wrote:
>> I would like to read directly in the final string object. I think it could
>> be done using the buffer API in recent Python branches.
> But is the string object useful from Python programmer's point of view
> then? (maybe NumPy?)
Yep, NumPy is good for that, but it is a separate API. Here I would like to do
just small optimization for ReadRaster call. Certainly we can save one buffer
allocation/copy/deallocation cycle.
> I can let Perl allocate memory for a Perl string
> and then *possibly* give that buffer to the RasterIO, but the Perl
> string still needs to be unpacked by the Perl hacker. There are cases
> when the binary buffer is ok - for example in libral (C), and then in
> Geo::Raster (Perl) I do just that - but for the average Joe Perl Hacker
> it would be good to put it into a Perl 2D array - i.e., each number into
> its own scalar. That I could do in standard typemaps, but as I wrote,
> the interface is different from Band.ReadRaster, which returns the
> string. I have defined a ReadTile/WriteTile interface(*), which do just
> that, but currently the implementation is the read->copy->copy, and the
> 2nd one in Perl, which makes it even a bit slower.
> (*) see
> http://geoinformatics.tkk.fi/doc/Geo-GDAL/html/class_geo_1_1_g_d_a_l_1_1_band.html
I will take a look at Perl part in more details and come with some suggestion
later. I think we can arrange something useful for both bindings.
Andrey V. Kiselev
