[gdal-dev] Python (2.6.5) GDAL module will not install with easy_install
Allen Rongone arongone at aer.com
Thu May 6 11:55:11 EDT 2010
Hello All,
	New here so don't beat me up to bad.
	I'm trying to get the GDAL module to install on a Red Hat Enterprise
Linux 5.4 64-bit workstation running Python 2.6.5.
	I have installed the setuptools 0.6c11 and am using easy_install
	My gdal-config is in /usr/bin, however, when I run easy_install GDAL
it complains that it "Could not run gdal-config!!!" and then contiues
on complaining about a bunch of stuff not
	being declared.
	I can not find the setup.py to edit and change the location of gdal-
config. easy_install must clean everything up if it fails.
	Does anyone know how to get this to work or will we have to do
without GDAL in python?
Thanks for any help,
Allen
I've included everything I thought pertinent below:
[root at psd14 ~]# uname -a
Linux psd14.aer.com 2.6.18-164.15.1.el5 #1 SMP Mon Mar 1 10:56:08 EST
2010 x86_64 x86_64 x86_64 GNU/Linux
[root at psd14 ~]# python
Python 2.6.5 (r265:79063, May  3 2010, 14:23:56)
[GCC 4.1.2 20080704 (Red Hat 4.1.2-46)] on linux2
Type "help", "copyright", "credits" or "license" for more information.
KeyboardInterrupt
[root at psd14 ~]# which gdal-config
/usr/bin/gdal-config
[root at psd14 ~]# easy_install GDAL
Searching for GDAL
Reading http://pypi.python.org/simple/GDAL/
Reading http://www.gdal.org
Best match: GDAL 1.7.1
Downloading http://pypi.python.org/packages/source/G/GDAL/GDAL-1.7.1.tar.gz#md5
=38b838d528b309a28a3aa24d4fcef3cd
Processing GDAL-1.7.1.tar.gz
Running GDAL-1.7.1/setup.py -q bdist_egg --dist-dir /tmp/easy_install-
eKZHzW/GDAL-1.7.1/egg-dist-tmp-siVuDI
Could not run gdal-config!!!!
cc1plus: warning: command line option "-Wstrict-prototypes" is valid
for Ada/C/ObjC but not for C++
extensions/gdal_wrap.cpp: In function $(B!F(Bint
GDALDriverShadow_Rename(GDALDriverShadow*, const char*, const char*)$
(B!G(B:
extensions/gdal_wrap.cpp:3371: error: $(B!F(BGDALRenameDataset$(B!
G(B was not declared in this scope
extensions/gdal_wrap.cpp: In function $(B!F(BCPLErr
GDALDatasetShadow_CreateMaskBand(GDALDatasetShadow*, int)$(B!G(B:
extensions/gdal_wrap.cpp:3744: error: $(B!
F(BGDALCreateDatasetMaskBand$(B!G(B was not declared in this scope
extensions/gdal_wrap.cpp: In function $(B!F(Bchar**
GDALDatasetShadow_GetFileList(GDALDatasetShadow*)$(B!G(B:
extensions/gdal_wrap.cpp:3747: error: $(B!F(BGDALGetFileList$(B!
extensions/gdal_wrap.cpp: In function $(B!F(BGDALRasterBandShadow*
GDALRasterBandShadow_GetMaskBand(GDALRasterBandShadow*)$(B!G(B:
extensions/gdal_wrap.cpp:4077: error: $(B!F(BGDALGetMaskBand$(B!
GDALRasterBandShadow_GetMaskFlags(GDALRasterBandShadow*)$(B!G(B:
extensions/gdal_wrap.cpp:4080: error: $(B!F(BGDALGetMaskFlags$(B!
GDALRasterBandShadow_CreateMaskBand(GDALRasterBandShadow*, int)$(B!
G(B:
extensions/gdal_wrap.cpp:4083: error: $(B!F(BGDALCreateMaskBand$(B!
extensions/gdal_wrap.cpp: In function $(B!F(Bvoid
GDALColorTableShadow_CreateColorRamp(GDALColorTableShadow*, int, const
GDALColorEntry*, int, const GDALColorEntry*)$(B!G(B:
extensions/gdal_wrap.cpp:4147: error: $(B!F(BGDALCreateColorRamp$(B!
ComputeProximity(GDALRasterBandShadow*, GDALRasterBandShadow*, char**,
int (*)(double, const char*, void*), void*)$(B!G(B:
extensions/gdal_wrap.cpp:4306: error: $(B!F(BGDALComputeProximity$
RasterizeLayer(GDALDatasetShadow*, int, int*, OGRLayerShadow*, void*,
void*, int, double*, char**, int (*)(double, const char*, void*),
void*)$(B!G(B:
extensions/gdal_wrap.cpp:4342: error: $(B!F(BGDALRasterizeLayers$(B!
Polygonize(GDALRasterBandShadow*, GDALRasterBandShadow*,
OGRLayerShadow*, int, char**, int (*)(double, const char*, void*),
void*)$(B!G(B:
extensions/gdal_wrap.cpp:4362: error: $(B!F(BGDALPolygonize$(B!G(B
FillNodata(GDALRasterBandShadow*, GDALRasterBandShadow*, double, int,
char**, int (*)(double, const char*, void*), void*)$(B!G(B:
extensions/gdal_wrap.cpp:4378: error: $(B!F(BGDALFillNodata$(B!G(B
SieveFilter(GDALRasterBandShadow*, GDALRasterBandShadow*,
GDALRasterBandShadow*, int, int, char**, int (*)(double, const char*,
extensions/gdal_wrap.cpp:4394: error: $(B!F(BGDALSieveFilter$(B!
RegenerateOverviews(GDALRasterBandShadow*, int,
GDALRasterBandShadow**, const char*, int (*)(double, const char*,
extensions/gdal_wrap.cpp:4408: error: invalid conversion from $(B!
F(BGDALRasterBandShadow*$(B!G(B to $(B!F(BGDALRasterBand*$(B!G
(Bextensions/gdal_wrap.cpp:4408: error:   initializing argument 1 of
$(B!F(BCPLErr GDALRegenerateOverviews(GDALRasterBand*, int,
GDALRasterBand**, const char*, int (*)(double, const char*, void*),
void*)$(B!G
(Bextensions/gdal_wrap.cpp:4408: error: invalid conversion from $(B!
F(BGDALRasterBandShadow**$(B!G(B to $(B!F(BGDALRasterBand**$(B!G
(Bextensions/gdal_wrap.cpp:4408: error:   initializing argument 3 of
void*)$(B!G
(Bextensions/gdal_wrap.cpp: In function $(B!F(Bint
RegenerateOverview(GDALRasterBandShadow*, GDALRasterBandShadow*, const
char*, int (*)(double, const char*, void*), void*)$(B!G(B:
extensions/gdal_wrap.cpp:4421: error: invalid conversion from $(B!
(Bextensions/gdal_wrap.cpp:4421: error:   initializing argument 1 of
void*)$(B!G
(Bextensions/gdal_wrap.cpp:4421: error: invalid conversion from $(B!
(Bextensions/gdal_wrap.cpp:4421: error:   initializing argument 3 of
void*)$(B!G
F(BGDALTransformerInfoShadow*
new_GDALTransformerInfoShadow(GDALDatasetShadow*, GDALDatasetShadow*,
char**)$(B!G(B:
extensions/gdal_wrap.cpp:4445: error: $(B!
F(BGDALCreateGenImgProjTransformer2$(B!G(B was not declared in this
scope
GDALTransformerInfoShadow_TransformPoint__SWIG_0
(GDALTransformerInfoShadow*, int, double*)$(B!G(B:
extensions/gdal_wrap.cpp:4456: error: $(B!F(BGDALUseTransformer$(B!
GDALTransformerInfoShadow_TransformPoint__SWIG_1
(GDALTransformerInfoShadow*, double*, int, double, double, double)$(B!
G(B:
extensions/gdal_wrap.cpp:4468: error: $(B!F(BGDALUseTransformer$(B!
GDALTransformerInfoShadow_TransformPoints(GDALTransformerInfoShadow*,
int, int, double*, double*, double*, int*)$(B!G(B:
extensions/gdal_wrap.cpp:4550: error: $(B!F(BGDALUseTransformer$(B!
extensions/gdal_wrap.cpp: In function $(B!F(BGDALDriverShadow*
IdentifyDriver(const char*, char**)$(B!G(B:
extensions/gdal_wrap.cpp:4661: error: $(B!F(BGDALIdentifyDriver$(B!
extensions/gdal_wrap.cpp: In function $(B!F(BPyObject*
_wrap_ReadDir(PyObject*, PyObject*)$(B!G(B:
extensions/gdal_wrap.cpp:5255: error: $(B!F(BVSIReadDir$(B!G(B was
error: Setup script exited with error: command 'gcc' failed with exit
status 1
[root at psd14 ~]#
