[gdal-dev] Python (2.6.5) GDAL module will not install with easy_install
Christopher Barker Chris.Barker at noaa.gov
Thu May 6 13:01:35 EDT 2010
Allen Rongone wrote:
>     I can not find the setup.py to edit and change the location of
> gdal-config. easy_install must clean everything up if it fails.
yes, it's a bit annoying that way.
>     Does anyone know how to get this to work or will we have to do
> without GDAL in python?
I"d do without easy-install instead.
Download the source yourself, and try to run that setup.py -- See Ari's
not for a hint or two that might help.
If that doesn't work, post again here.
-Chris
Christopher Barker, Ph.D.
Oceanographer
Emergency Response Division
NOAA/NOS/OR&R            (206) 526-6959   voice
7600 Sand Point Way NE   (206) 526-6329   fax
Seattle, WA  98115       (206) 526-6317   main reception
