[gdal-dev] Will gdalinfo generate the pam .aux.xml files?
Rubin, Jared JARED.RUBIN at saic.com
Mon May 10 14:13:36 EDT 2010
That sucks. I have hundreds of images on disk and would like to just have the xml file for each file so that I can just do fast "greps" for specfic tags.
What is the reason behind this design choice? Also are any of the gdalinfo calls quick?
Jared
-----Original Message-----
From: Chaitanya kumar CH [mailto:chaitanya.ch at gmail.com]
Sent: Thu 5/6/2010 10:43 PM
To: Rubin, Jared
Cc: gdal-dev at lists.osgeo.org
Subject: Re: [gdal-dev] Will gdalinfo generate the pam .aux.xml files?
Jared,
For gdalinfo to create .aux.xml files, you just need to force it to compute
some metadata not stored in the file.
On Fri, May 7, 2010 at 2:39 AM, Rubin, Jared <JARED.RUBIN at saic.com> wrote:
>  I am using gdal-1.6.2 (version not important) and would like for gdalinfo
> to generate  .aux.xml files  for NITF files that I have on disk, is this
> possible?
> If this is possible, will gdalinfo just load an  image.nitf.aux.xml file
> instead of image.nitf?
> Thanks
> Jared
> gdal-dev mailing list
Best regards,
Chaitanya kumar CH.
/t?a???nj?/ /k?m?r/
+91-9848167848
17.2416N 80.1426E
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20100510/9731dde4/attachment.html
