[gdal-dev] get different result when use different parameters
Chaitanya kumar CH chaitanya.ch at gmail.com
Tue May 11 02:02:42 EDT 2010
weixj2003ld,
I couldn't open the link.
Try "gdalinfo -mm des.png" on both the output images. I think they will both
give the same output. UInt16 should give a dark image unless you perform
histogram equalization on it.
2010/5/11 weixj2003ld <weixj2003ld at 163.com>
> I download a elevation data (SRTM,GTOPO30) from
> http://glcfapp.glcf.umd.edu:8080/esdi/index.jsp
>  use
> and
> differently,
> with parameter 'UInt16',I get a black picture,with Byte,get a different
> one,why?
> BTW,I want to get a png file from elevation data(.tif),must I use command
> gdal_translate?
> Thk u in advance.
> 网易为中小企业免费提供企业邮箱(自主域名) <http://ym.163.com/?from=od3>
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Best regards,
Chaitanya kumar CH.
/tʃaɪθənjə/ /kʊmɑr/
+91-9848167848
17.2416N 80.1426E
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20100511/dd79890d/attachment.html
